07 wrangler remote start issue
luigirox2
Member - Posts: 8
Posted: January 01, 2009 at 2:22 PM / IP Logged
Trying to install a remote start in a 07 wrangler and having issues using the 2 relays. Are they two starter wires? The  PURPLE / brown i cut and wireded to two relays
one right after the key and is ground when the relay is avtive to a 600 ohm resitore. Th second relay is ground to a 180 ohm resitor and after the cut mux wire.
No the diagram I hav says the normal contction to the start wire is still required? so i am not sure what that means. I am not sure what i am missing not sure if there is another starter wire any help would be great I already have a bypass unit that useses a key can't rtuen it so i would lik to us it.
dtk1
Copper - Posts: 179
Posted: January 01, 2009 at 2:37 PM / IP Logged
this cars can be easy or hard depending on what way you approach it I would recommend you taking out you relay and risitors and used something like http://www.bypasskit.com/product.aspx?prodid=PKUCH2GX witch would do your MUX and transponder how ever if you have wired all up all your going to wire up on the ing harness is your MUX and ignition that's all you need to make this car start. follow this and make sure its all this way CLICK HERE
luigirox2
Member - Posts: 8
Posted: January 01, 2009 at 2:50 PM / IP Logged
I have tried th relay solution and the jeep doesn't crank unless i also hook the starter wire from the remote start to the mux wire. The acc work threw the relay just the vechile doen't crank
thanks
luigirox2
Member - Posts: 8
Posted: January 01, 2009 at 2:52 PM / IP Logged
I also saw a diagram at buldog security that say there are two starter wire and one on the mux wich I know but the yellow/grey and i am not sure were that is.
thanks
dtk1
Copper - Posts: 179
Posted: January 01, 2009 at 3:19 PM / IP Logged
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red     +     battery or TIPM
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger fender.
Second 12 Volts     lt. blue/red (10A)     +     ignition switch, black 5 pin plug, pin 5
Starter     yellow/gray (not for remote start)     +     firewall under hood, black 34 pin plug or TIPM, blue plug, pin 8
Second Starter     PURPLE / brown     - 180 ohms     ignition switch, black 5 pin plug, pin 2
     If interface module is not available, see Tech Doc 1084 for wiring information.
Ignition     pink/white     +     ignition switch, black 5 pin plug, pin 3
Second Ignition     N/A
Third Ignition     N/A
Accessory     same as second starter     - 560 ohms
Second Accessory     N/A
Third Accessory     N/A
Keysense     same as second starter     -8.5K ohms
Data Bus     N/A
Can Bus High     WHITE/ lt. green (CAN C BUS)     data     SKREEM, black 8 pin plug, pin 6
     The SKREEM (Sentry Key Remote Entry Module) is around the ignition key switch. The CAN Interior BUS High wire is WHITE/ orange at the instrument cluster, brown 20 pin plug, pin 16 or the TIPM, white plug, pin 26. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger fender.
Can Bus Low     WHITE/ lt. blue (CAN C BUS)     data     SKREEM, black 8 pin plug, pin 7
     The SKREEM (Sentry Key Remote Entry Module) is around the ignition key switch. The CAN Interior BUS Low wire is white at the instrument cluster, brown 20 pin plug, pin 15 or the TIPM, white plug, pin 27. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger fender.
Can Bus Sw     N/A
Power Lock     PURPLE / lt. green     - 330 ohms     driver kick or TIPM, white plug, pin 2
Power Unlock     same as power lock     - 100 ohms
Lock Motor     tan/lt. green to tan/white     5 wire     driver kick or TIPM, gray plug, pin 8
Driver Unlock Motor     tan/brown to tan/lt. green     5 wire     driver kick or TIPM, gray plug, pin 3
Passenger Unlock Motor     tan/brown to tan     5 wire     passenger kick or TIPM, brown plug, pin 5
Parking Lights (-)     (LIN BUS)
Parking Lights (+)     WHITE/ orange (L), WHITE/ purple (R)     +     passenger kick or TIPM, brown plug, pins 8 and 36
Hazards     WHITE/ dk. blue     -     hazard switch or TIPM, white plug, pin 9
Turn Signal (Left)     WHITE/ lt. green (F), WHITE/ dk. green (R)     +     turn signal light (F); passenger kick, harness to rear (R)
     Also found at the TIPM, lt. gray plug, pin 9 and white plug, pin 49. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger fender.
Turn Signal (Right)     WHITE/ tan (F), WHITE/ yellow (R)     +     turn signal light (F); passenger kick, harness to rear (R)
     Also found at the TIPM, lt. gray plug, pin 7 and white plug, pin 50. The TIPM (Totally Integrated Power Module) is in the engine compartment, on the passenger fender.
Headlight     WHITE/ dk. blue (L), WHITE/ tan (R)     +     headlights or TIPM, green plug, pins 3 and 11
AutoLights     N/A
Reverse Light     WHITE/ gray     +     passenger kick or TIPM, brown plug, pin 15
Left Front Door Trigger     PURPLE / white to purple     -     driver kick or TIPM, white plug, pin 11
Right Front Door Trigger     PURPLE / white     -     passenger kick or TIPM, white plug, pin 12
Left Rear Door Trigger     purple / YELLOW to PURPLE / gray     -     passenger kick or TIPM, white plug, pin 16
Right Rear Door Trigger     purple / YELLOW     -     passenger kick or TIPM, white plug, pin 14
Dome Supervision     yellow/white     +     passenger kick or instrument cluster, brown 20 pin plug, pin 4
     Also found at the underdash light, if equipped.
Trunk/Hatch Pin     PURPLE / orange     -     passenger kick or TIPM, white plug, pin 15
Rear Glass Pin     N/A
Hood Pin     PURPLE / lt. blue (export model only)     -     hood switch or TIPM, lt. gray plug, pin 3
Trunk/Hatch Release     N/A
Trunk Release Motor     lt. GREEN / WHITE (unlock only)     5 wire     passenger kick or TIPM, brown plug, pin 17
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     factory remote only
Disarm No Unlock     Sentry Key, ignition, and keysense
Trunk Alarm Shunt     N/A
Tachometer     NOT BROWN / white     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     black (in), yellow/orange (out)     - N.O.     clutch pedal switch
Fuel Pump     dk. blue/orange     +     passenger kick or TIPM, brown plug, pin 10
Rear Defroster     dk. blue/white     + latched     passenger kick or TIPM, brown plug, pin 32
Mirror Defroster     N/A
Left Front Heated Seat     N/A
Right Front Heated Seat     N/A
Speed Sense     dk. GREEN/ brown     ac     PCM, plug towards passenger side, pin 32
     The PCM (Powertrain Control Module) is in the engine compartment, on the driver fender.
Brake Wire     WHITE/ tan     +     brake pedal switch or TIPM, white plug, pin 10
Parking Brake     dk. GREEN / WHITE     -     parking brake switch or instrument cluster, brown 20 pin plug, pin 7
Horn Trigger     dk. GREEN/ purple     -     horn switch or instrument cluster, black 20 pin plug, pin 10
Wipers     BROWN / white (L), BROWN / orange (H)     +     wiper motor or TIPM, brown plug, pins 12 and 11
Left Front Window (Up/Down)     lt. blue - white     A     front power window switch, 14 pin plug, pins 14 and 13
Right Front Window (Up/Down)     BROWN / lt. blue - PURPLE / white     A     front power window switch, 14 pin plug, pins 7 and 3
Left Rear Window (Up/Down)     ORANGE / white - ORANGE / gray     A     front power window switch, 14 pin plug, pins 8 and 9
Right Rear Window (Up/Down)     ORANGE / lt. blue - ORANGE / dk. blue     A     front power window switch, 14 pin plug, pins 1 and 2
luigirox2
Member - Posts: 8
Posted: January 01, 2009 at 3:24 PM / IP Logged
thanks so with the relay I do not have to use the yellow grey starter wire?
It should start with just the 180 ohm grounded to the mux correct?
Thank for the help
thanks
dtk1
Copper - Posts: 179
Posted: January 01, 2009 at 6:44 PM / IP Logged
Yes the mux and ing and car starts rigth up
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
