2006 Pontiac G6 Alarm/Remote Start Wiring
magnumwheels
Posted: January 04, 2009 at 1:20 AM / IP Logged
Hello I need help with a wiring diagram for a 2006 Pontiac G6. This would be for security and remote start. Appreciate any responses thanx!
Magnum Man
oneohm
Member - Posts: 9
Posted: January 04, 2009 at 9:54 PM / IP Logged
12voltsRED / black (50A)+BCM, C3, pin D1
Starteryellow or PURPLE / white (not for remote start)-,+PCM, blue plug, pin 23 or 26
Ignitionpink+ignition harness or BCM, C4, pin D3
Second Starterwhite+9.6K ohmsignition harness or BCM, C2, pin 56
Power Lockwhite-driver kick or BCM, C1, pin 66
Power Unlocksame as power lock wire-1.5K ohms
Lock Motorgray/black to gray5 wiredriver kick or BCM, C3, pin A5
Unlock Motortan5 wiredriver kick or BCM, C3, pin B1
Disarm Defeattan5 wirepassenger kick or BCM, C3, pin A2
Parking Lights+brown+BCM, C3, pin A7
Parking Lights-BROWN / white-switch or BCM, C2, pin 5
Hazardswhite-switch or BCM, C2, pin 9
Turn Signal(L)lt. blue/white (F), yellow (R)+BCM, C1, pin 38 (F), C3, pin A9 (R)
Turn Signal(R)dk. blue/white (F), dk. green (R)+BCM, C1, pin 56 (F), C3, pin A12 (R)
Door Triggergray/black-driver kick or BCM, C1, pin 51
Dome Supervisiongray-BCM, C3, pin A10
Trunk/Hatch PinORANGE / black-BCM, C1, pin 18
Hood Pinpink/black-pin switch or BCM, C1, pin 69
Trunk/Hatch ReleaseBROWN / white-driver kick or BCM, C1, pin 71
Power Sliding DoorN/A
Factory Alarm Armfactory remote only
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ignition and Passkey
TachometerNOT pinkacany fuel injector
Horn Triggertan-switch or BCM, C2, pin 14
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console.
It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
xplorin16
Copper - Posts: 52
Posted: January 05, 2009 at 1:15 AM / IP Logged
xk06 will save your life on this vehicle.  Just about all connections are around center console.  Some on pass side some on driver side.
Advanced MECP
magnumwheels
Posted: April 12, 2009 at 12:07 AM / IP Logged
Thanks fellas your responses worked wonders!!!!
Magnum Man
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
