Anyone Know About Welding?
busabusa
Member - Posts: 14
Posted: March 31, 2003 at 6:16 PM / IP Logged
You could try this I copied it off a web site
Lumiweld Kit can be used anywhere to make a strong fused joint [similar to brazing], using only a butane blow lamp as a heat source. It will work on almost any type or grade of aluminium including Dural, Birmabrite [Land Rover bodywork], zinc alloys, Mazak, pot metal and die cast, resulting in a joint stronger than the parent metal. Tried and tested widely in motorcycle magazine workshops, Lumiweld has hundreds of applications for the car restorer too, such as broken carb flanges, thermostat housings, rocker covers, cracked aluminium engine blocks and cylinder heads, etc.
Thanks,Rick Phillips
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
