proximity sensor wiring
romeo204
Posted: January 15, 2009 at 1:16 PM / IP Logged
hi you guys, I currently owned a Nustart 8000r two way start/alarm lcd combo. (very similar to compustart 2way pager)
My question is, How do I properly connect my DEI Proximity sensor (508D)
the proximity came with 4 wires
+ (pos)
- (neg)
warn (outer zone) green wire i think
alarm (inner zone) blue wire
anyways, do I just directly tap this wires to my shock sensor wire and go by color codings? red to red black to black and so on?
I'm really eager to get this damn thing installed but I just wanna make sure I know what I'm doing, Plus here in canada, right now its just about MINUS FREAKING 30! you should be frozen in just a few minutes, my little garage with poor insulations is a lil help but still... so please please help.
91stt
Silver - Posts: 564
Posted: January 15, 2009 at 1:39 PM / IP Logged
the red and black wires, you can connect together but the trigger wires need to be diode isolated so you don't get false alarms due to feedback from the sensors. You will need four 1N4001 diodes, connect the cathode (band end) towards the sensor and the other end towards the alarm. You need to do this for all four trigger wires. Once done, adjust as usual and you're all set.
romeo204
Posted: January 15, 2009 at 3:58 PM / IP Logged
First i wanna thank you for your reply, but can you please be more specific how to set it up?
so basically you meant to say, each sensorS will have a diode (blueS and greenS = 4 diodes) leading to the alarm unit?
[Shock Sensor] --- diodes --------------->Alarm Mail Unit
[Proxy Sensor] --- diodes -------/
Is this correct?
romeo204
Posted: January 15, 2009 at 4:03 PM / IP Logged
whoops, i meant
[Proxy sensor]--diodes--- taps to the shock sensor wires AFTER the shock sensor's diodes, right?
Sorry, I a novice at electrical stuff.
91stt
Silver - Posts: 564
Posted: January 15, 2009 at 4:42 PM / IP Logged
here is an example, you need to do this with both warning and alarm triggers. pic only shows one.
http://home.att.net/~turbostealth/host/diode_iso.jpg
romeo204
Posted: January 16, 2009 at 9:29 AM / IP Logged
got The picture, thank you for all your help, i'll go ahead and buy them diodes. i'll keep you posted
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
