viper5900 on bmw 96 328is coupe
foxracr1010
Posted: January 18, 2009 at 6:19 PM / IP Logged
I am installing this on a 96 328is coupe. Does anyone have a wiring diagram? Also I can not find the tach wire any help? Does this need a resistor in it for the key bypass? and if so how do I find out the resistance? Thanks in advance!
another-kelly
Silver - Posts: 618
Posted: January 18, 2009 at 6:59 PM / IP Logged
for a 1996 BMW 328IS 2DR SEDAN Audiovox lists:
     Remote Start
     WIRE          COLOR          POLARITY          LOCATION
Battery          RED / GREEN          (+)          OR RED / BLU IGNITION HARNESS
Ignition 1          GREEN          (+)          IGN HARNESS GRN ALARM PLUG
Ignition 2          VIOLET          (+)          OR VIO/WHT IGNITION HARNESS
Accessory 1          VIOLET          (+)          IGN HARNESS OR VIO/WHT ALARM PLUG
Starter 1          BLACK/ BLUE          (+)          IGN HARNESS GRN/BLK ALARM PLUG
Anti-Theft Type          RF ACTIVATED SYS.
Anti-Theft Descript          EWS II
Tachometer          BLACK          (-)          DIA. PLUG PASS SIDE OF ENG ROUND BLK PLU
Speed Sense          BROWN / RED          (AC)          IN HARNESS FROM GAUGES
Parking Lights          REMOVE SWITCH          (+)          4TH WIRE FROM LEFT ON RIBBON CABLE (NOTE FOURTH WIRE FROM LEFT LOOKING AT SWITCH IN RIBBON CABLE
Brake Lights          BROWN / WHITE          (+)          SWITCH ABOVE BRAKE PEDAL
Horn          BROWN / RED          (-)          STEERING COLUMN
Power Unlock          BLUE/RED          (-)          PIN 22 THIS WILL DISARM ALARM DOUBLE PULSE
PowerLock          WHITE/ BLACK          (-)          PIN 20 OF MODULE BEHIND GLOVE BOX
another-kelly
Silver - Posts: 618
Posted: January 18, 2009 at 7:01 PM / IP Logged
and you have to give a key up to bypass for remote start
click here for bypass info
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
