will i blow my amp
jesse88
Posted: January 20, 2009 at 8:21 PM / IP Logged
i have just bought an AA0460 response class d mono block amp and i wanna hook it up to two cerwin vega XL-12D duel voice coil subs the subs are rated at 125w rms per voice coil so 250w rms per sub and they are 4 ohms per voice coil. i have these subs wired up positive to positive and negative to negative so they are 2 ohms per sub i then wanna hook these subs up together positive to positive and negative to negative so together they are 1 ohm total then wire them to my amp in bridge so positive off 1 channel and negative off the other channel would this work or would i blow my amp?
specs for my amp are:
Power/channel @ 1 ohm mono 14.4v = 1000w rms x 1
Power/channel @ 2 ohm mono 14.4v = 600w rms x 1
Power/channel @ 4 ohm mono 14.4v = 300w rms x 1
Thanx in advance, Jesse
haemphyst
Platinum - Posts: 5,059
Posted: January 20, 2009 at 9:22 PM / IP Logged
It's a mono amp. There is no "bridge". I have no idea who or what the manufacturer of that amp is, but what fuses are in it?
Four 4-ohm voice coils all wired in parallel is 1 ohm. If the amp is reasonable or even half respectable, it'll be safe driving a 1 ohm load, as claimed...
Platinum - Posts: 13,726
Posted: January 20, 2009 at 9:23 PM / IP Logged
Isn't it a 1 channel amplifier?  If it has 2 positive and 2 negative speaker terminals on the amp, they are connected together internally.  According to the specs you posted, the amp will handle a 1 ohm load.
j.reed
Copper - Posts: 716
Posted: January 20, 2009 at 9:35 PM / IP Logged
The reason a mono block has more than one positive /negitive is to make it easier to install more than one sub when you have more than one lead running to the amp. As i am an idiot said above. It is connected together internally. The 2 positives and negitives are going to the same spot. So it makes no differance which positive or neg you use to hook up your leads on a MONO block
will i blow my amp - Last Post -- posted image.
