audiovox remote car starter problem
new2thisforum
Posted: January 22, 2009 at 3:53 PM / IP Logged
Hello I have a audiovox remote ( ELVAT8B) installed on my accord 99 model. This is an after market install and has been working for many years. This year the Remote is not starting the car. It cranks the engine but does not start. However if I have the key in the ignition or near the ignition the car starts with the remote starter. I have all the 3 keys with me. Reading through the forums it talks about reprogramming the keys/ remote? or an issue with immobiliser. Can some one guide me with troubleshooting steps?
Many thanks in advance.
james bond 007
Copper - Posts: 62
Posted: January 22, 2009 at 4:58 PM / IP Logged
If your immobilizer has a spare key in it, you will have to find the box under your dash and check to see if the key has moved out of position, if your immobilizer was the the type that doesn't have a key in the box, it is probibly the wire ring going around the ignition switch under the sterring wheel cover, it could have just come unplugged from the box or maybe the wire was cut or pinched going to the ring (antenna)
new2thisforum
Posted: January 22, 2009 at 5:47 PM / IP Logged
Bond:
Thanks for the suggestion. I  dont think it has a sapre key as I have all the 3 keys with me. Mine is an accord 99 model. How do I remove the stearing wheel cover? Any suggestions?
advanced
Copper - Posts: 207
Posted: January 22, 2009 at 7:01 PM / IP Logged
There is usually a few screws under the plastic ignition column shroud. Remove those & then carefully separate the top & bottom halves.
You will expose the ignition & maybe a loose or disconnected coil ring.
Did you buy the car new? There may be other keys.
Good Enough Isn't!
Chris Luongo
Platinum - Posts: 3,746
Posted: January 22, 2009 at 10:17 PM / IP Logged
First get underneath the dash......it's all open under there and there are no covers. Just get up under there with a flashlight, and see what aftermarket items you see.
You'll see the main remote starter brain, probably zip-tied to some of the factory braces or wiring.
But you should also see another, second smaller item, also tied in place.
See if you can get any part or model numbers off of that smaller part, so we can see what they used for an immobilizer bypass.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
