2008 pontiac grand prix
jnjm2003
Member - Posts: 8
Posted: January 25, 2009 at 7:07 PM / IP Logged
I am looking for wiring information for 2008 Pontiac Grand Prix.
Platinum - Posts: 13,725
Posted: January 25, 2009 at 7:13 PM / IP Logged
For the entire car, or just remote start, alarm or audio.  Posting the wiring for the entire vehicle takes up entirely too much bandwidth.
jnjm2003
Member - Posts: 8
Posted: January 25, 2009 at 7:29 PM / IP Logged
Remote start.
Posted: January 25, 2009 at 7:52 PM / IP Logged
WIRECOLORPOLARITYLOCATION 2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.BatteryRED(+)AT VEHICLE FUSEBOX UNDER PASSENGER SIDE OF DASH
2008 pontiac grand prix - Last Post -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
2008 pontiac grand prix - Last Post -- posted image.Ignition 2WHITE(+)IGNITION SWITCH HARNESS
2008 pontiac grand prix - Last Post -- posted image.Accessory 1BROWN(+)IGNITION SWITCH HARNESS
2008 pontiac grand prix - Last Post -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
2008 pontiac grand prix - Last Post -- posted image.Anti-Theft TypeGM PASSKEY III® VEHICLE IMMOBILIZER
2008 pontiac grand prix - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2008 pontiac grand prix - Last Post -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
2008 pontiac grand prix - Last Post -- posted image.TachometerWHITE(AC)AT IGNITION CONTROL MODULE ON DRIVERS SIDE OF ENGINE
2008 pontiac grand prix - Last Post -- posted image.Crankshaft SensorDARK BLUE/WHITE(AC)AT PCM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.Camshaft SensorBROWN / WHITE(AC)AT PCM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.Speed SenseDARK GREEN(AC)AT THROTTLE ACTUATOR MODULE ON TOP OF ENGINE
2008 pontiac grand prix - Last Post -- posted image.Parking LightsBROWN(+)AT VEHICLE FUSEBOX UNDER PASSENGER SIDE OF DASH
2008 pontiac grand prix - Last Post -- posted image.Brake LightsWHITE(+)AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.Reverse LightsLIGHT GREEN(+)AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.HornBROWN(-)AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.Anti Theft RXWHITE(+)AT PASSKEY SENSOR IN IGNITION COLUMN2008 pontiac grand prix - Last Post -- posted image.
2008 pontiac grand prix - Last Post -- posted image.Anti Theft TXBLACK(-)AT PASSKEY SENSOR IN IGNITION COLUMN
crewc5
Posted: March 05, 2009 at 1:11 PM / IP Logged
How about the radio diagram for the 08 Grand Prix? More or less need to know which wires run the back speakers and more importantly which are neg and pos for the hi/low switch. Im not sure if the 2 blue and yellow/brown sets on the speakers are the same wires all the way to the radio or if theres a pre-amp or anything like that. Any help is GREATLY appreciated.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
