two ignition wires, how to wire relay
munda
Member - Posts: 6
Posted: January 29, 2009 at 12:20 AM / IP Logged
Hey,
I tried to search but couldnt find anything on how to wire my 2 ignition wire's to a relay. Its a 2000 rav4
Right now I have them hooked together and I know thats not the proper way and I would like to know how to do it proper.
Thanks in advance
munda
Member - Posts: 6
Posted: January 29, 2009 at 12:31 AM / IP Logged
Forgot to metion this is a alarm/starter haha
its the compustar pro2wsass
lostissues
Copper - Posts: 103
Posted: January 29, 2009 at 1:19 AM / IP Logged
It looks like there are 2 ignitions and 1 accessory in that car. your starter im assuming (only have the manual for the CM3000 brain) but it is most likely the same and should have a pre wired relay and you should just have to run the - ignition wire to the relay.
Jonathan
munda
Member - Posts: 6
Posted: January 29, 2009 at 1:36 AM / IP Logged
Both ignitions are positive...
I have them joined together as one right now but i know that wrong.
If you use a relay you can make those 2 into one.
munda
Member - Posts: 6
Posted: January 29, 2009 at 8:26 AM / IP Logged
I ran across this diagram but its for when you have 2 starter wires. I have 2 ignition wires is it the same procedure or is the wiring different? http://www.commandocaralarms.com/2ndstarterwire.asp
lostissues
Copper - Posts: 103
Posted: January 29, 2009 at 6:19 PM / IP Logged
Ok what I meant is that there should already be a relay set up that you can use for 2nd start/accessory/ignition depending on the trigger (in your case -ignition wire) you apply to the coil.
if you do not have that relay they you would have to add a relay set up like this:
85 - - ignition wire off of compustar
86 - 12 volts fused
87 - 12 volts fused
30 - goes to your second ignition wire in the car
that way 86 will be your positive trigger on your coil. the coil will activate when the -ign wire off the compustar goes to ground. that it will send pin 87 (12 volts) through to 30 and to your 2nd ignition wire in your car.
Jonathan
