common ground speaker system?
pv13
Copper - Posts: 158
Posted: January 29, 2009 at 2:30 PM / IP Logged
My cousin just bought a 1985 Econoline van (I know!). It has the factory am/fm stereo with one 6x8 or 6x9 speaker right behind it in the dash.
It has the two factory plugs for ford (one for power the other for speaker).
I talked to an installer, and he said that I might have a common ground speaker system, and I would have to rewire it.
I guess I want to know what a common ground speaker system is, and how do I get it to work with my aftermarket cd player.
Thanks,
forbidden
Platinum - Posts: 5,354
Posted: January 29, 2009 at 3:36 PM / IP Logged
Your aftermarket cd player is a floating ground unit. This means that the two are incompatable due to how they are wired. Floating grounds take the - leads of the speaker back to the new head unit. Common ground head units have 1 output for the - speaker leads that is grounded with the main ground of the head unit. The speakers - terminals are then grounded as well. You need to either buy a floating to common ground adaptor (if you can still find one), or rewire all the speakers in the vehicle (a far better option).
pv13
Copper - Posts: 158
Posted: January 29, 2009 at 5:10 PM / IP Logged
There is only one speaker in that he is going to be hooking up to the stereo, and it is right behind the stereo. So I just run a new set of speaker wires from the speaker to two speaker leads on the back of the aftermarket stereo right.
And then I put in place my new ground for the stereo, and everything should work fine right?
forbidden
Posted: January 30, 2009 at 4:07 AM / IP Logged
Yes that should be what you need to do.
pv13
Copper - Posts: 158
Posted: January 31, 2009 at 1:44 PM / IP Logged
Alright, Thanks.
