08 dodge ram 1500, remote start/alarm
mr_verbatim
Posted: January 30, 2009 at 11:33 PM / IP Logged
Hello,
I just purchased a remote start/alarm system from eBay - Item number: 370146901136, so you can see it. I also have a DA-CHDL7P2 Bypass Module (not sure if I need this now). As mentioned in the subject the vehicle is a Dodge RAM 1500 4 door SLT (HEMI). It currently has keyless entry and I am unsure about factory alarm. I really can't afford to have it installed by a shop at this point ( I just spent everything on the truck!)
I have installed countless stereo systems, amps and gadgets without a problem, but this is a new truck and I don't want to damage anything. I have never installed a remote start/alarm system such as this.
Basically, I could use a good 2008 wiring diagram for the truck and a "how-to" from some of you in the know! I'm intuitive with electronics and common sense is a given, but I know I'm out of my league here without some guidance.
I apologize if this is in the wrong forum; I had a good look around and this looked like the proper place.
BTW, I'm in the Windsor, Ontario area if anyone is nearby and could lend a hand, first-hand.
Thanks ahead of time,
Dan
mr_verbatim
Posted: January 30, 2009 at 11:38 PM / IP Logged
BTW, the wiring diag for the remote starter unit is located here:
http://autoditto.com/images/cx-2300-user-manual.pdf
The model of the unit is the CX-2300C - Manufacturer has many names, this one is Car-VOX
Dan
mr_verbatim
Posted: January 31, 2009 at 12:35 PM / IP Logged
Hello all,
I could use a wiring diagram for a 2008 Dodge RAM SLT 4 door. I see a 2007 diagram here on the site, but I didn't know if it was the same as the 08. This is to install a CX-2300C remote starter/alarm system.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
