Posted: January 31, 2009 at 10:37 PM / IP Logged
Posted: February 02, 2009 at 6:41 PM / IP Logged
Posted: February 03, 2009 at 12:53 PM / IP Logged
Posted: February 03, 2009 at 7:45 PM / IP Logged
Posted: February 03, 2009 at 8:02 PM / IP Logged
Posted: February 03, 2009 at 8:17 PM / IP Logged
Posted: February 03, 2009 at 9:52 PM / IP Logged
Friday, May 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
This may be a long post, but I want to cover everything. To give a little background: I'm not new to the car audio scene, but I've been out of the loop for about 15 years. The changes (in equipment and installations) are amazing! Wow, where did all of these brands come from? Seems a lot of the better companies are making junk.
All right, on to the questions and such!
What I plan to do is install a modest system in a 2008 and 2009 (yes 2) malibu. I want to keep the stock head unit (6cd/xm/aux input, RAP, OnStar, chimes) and replace/add from there.
The basis for the system will be:
New 6.5 components for the front doors
10" or 12" sub
Stock rear speakers for fill
45 to 65 watt per channel 4 channel amp with one side bridged for the sub.
Here are my questions...
1. It's cold out and I haven't been able to verify but it is my understanding that the 6 disk changer radios have an external amp. I would like to use the low level inputs to this amp as inputs to the new amp to eliminate a converter. Is this possible? Does the factory amp have a remote lead, or is it hot when the ignition is on? If not where are you guys getting remote power?
2. 6.5 components. I listen to a variety of music from jazz to hip-hop, but most is rock, 80's rock, grunge, and alternative. What is your suggestion for quality 6.5 components in the $150 to $200 range? I believe the depth is around 2.75". Does anyone know exactly?
3. I'm going to built a fiberglass/mdf enclosure on the right side of the trunk. Should have about 1.5 cubic ft max. I'm looking for a 10" or 12" - sealed or ported.
I'm leaning toward Alpine type R or RE Audio SE, what is your opinion for a $150 sub?
4. Amplifier. I'm leaning toward an Alpine MRP-F300 or JL AUDIO A4300. Thoughts?
Remember, I'm staying modest. I have to take the WAF (Wife Acceptance Factor) into account, lol!
Any help, suggestions, and/or information you can provide is much appreciated!
Dave
