matrix 2.2x with 904100 remote options
Champcar_Fan
Member - Posts: 6
Posted: February 01, 2009 at 1:56 PM / IP Logged
My original 487X remote started having problems and had to be replaced. Because of cost, I went with the 904100 replacement remote.
I've been able to program it to lock/unlock. I was wondering if there is a way to program the "panic" and the "Silent Mode" with this remote? The Slient Mode would be the preferable option if I can only program one of them, if at all.
Thanks!
Champcar_Fan
Member - Posts: 6
Posted: February 05, 2009 at 11:46 PM / IP Logged
For anyone interested, here is the way I programmed the Silent Mode using the * button.
1. Open the driver’s door.
2. Turn the ignition on.
3. Select the receiver channel: Press and release the Valet/Program button the number of times necessary to access the desired channel. For silent mode, it is channel 2.
Press and hold the Valet/Program button once more. The siren will chirp and the LED will blink the number of times corresponding to the channel that is accessed.
4. Press the transmitter button. While HOLDING the Valet/Program switch, press the button from the transmitter that you wish to assign to the selected channel. (In my case, it is the * button. ) The unit will chirp once indicating that the channel has been entered.
5. Press the same transmitter button again. While still HOLDING the
Valet/Program switch, press the same transmitter button that you just
programmed. The siren will chirp twice to confirm that the desired channel has been successfully programmed to the button. If this step is not performed, the channel will not be programmed to the button. It is not possible to teach a transmitter button to the system more than once.
6. Release. Once the code is learned, the Valet/Program button can be released.
To exit the learn routine:
One long chirp indicates that Learn Routine has been exited. Learn Routine will be exited if any of the following occurs:
•     Ignition is turned off.
•     Door is closed.
•     Valet/Program button is pressed too many times.
•     More than 15 seconds elapse between steps.
Posted: February 07, 2009 at 7:13 AM / IP Logged
N.B. to above if you have pos door contacts and are using the alarm's purple as your door trigger, ground the green.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
