foglights flash with alarm arm/disarm
nexlvl
Member - Posts: 35
Posted: February 16, 2009 at 5:41 PM / IP Logged
I have an 2004 Dodge Ram and I installed a crimestopper RS-2011 about three years ago recently the foglights have started to flash with the parking lights during arm/disarm and remote start. I have a 330 ohm resistor on the grn\wht wire behind the switch already. Is there any way I can resolve this issue? Thanks
nexlvl
loneranger
Copper - Posts: 572
Posted: February 16, 2009 at 6:13 PM / IP Logged
I believe it may be an issue, with a settings at the light switch. You have the fog light switch tunred on. Check your settings at the light switch.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
nexlvl
Member - Posts: 35
Posted: February 17, 2009 at 6:00 AM / IP Logged
I double checked the switch and the foglights are in the off position
nexlvl
Platinum - Posts: 13,726
Posted: February 17, 2009 at 6:26 AM / IP Logged
Have you tried disconnecting the battery for a few minutes.  This will reset the computer of the vehicle.
nexlvl
Member - Posts: 35
Posted: February 17, 2009 at 9:33 AM / IP Logged
No but I will give it a shot
nexlvl
moonliter
Copper - Posts: 322
Posted: February 17, 2009 at 10:32 AM / IP Logged
This should be an easy fix. Take another 330 ohms resistor, touch one end of the resistor to ground and the other end to the grn/wht at the switch. If only the parking lights come on then you know the problem is the resistor.
nexlvl
Member - Posts: 35
Posted: February 27, 2009 at 3:54 PM / IP Logged
Thanks it was the resistor
nexlvl
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
