2005 Honda Odyssey Reverse Wire
stupidpig
Member - Posts: 31
Posted: February 17, 2009 at 12:17 AM / IP Logged
Can anyone help me to locate the reverse wire on the Driver Side Kick Panel area for a Honda Odyssey 2005 EX-L w/RES (w/o Navi)? I attached the picture for that area with no. assigned. Thanks.
Top portion:
2005 Honda Odyssey Reverse Wire - Last Post -- posted image.
Bottom Portion:
Platinum - Posts: 13,725
Posted: February 17, 2009 at 12:34 AM / IP Logged
Reverse LightsGREEN(+)DRIVER KICK HARNESS TO REAR
In the drivers kick panel, there is a harness that travels toward the rear of the car,  remove the door sill and the kick panel, raise the carpet a bit, you should be able to find the harness and follow it to the area you are looking in.
