constant negative to pulse negative relay
lexelite
Copper - Posts: 82
Posted: February 21, 2009 at 1:39 AM / IP Logged
I found the relay diagram to convert constant positive to pulse, but not for a constant negative to pulse.
constant negative to pulse negative relay - Last Post -- posted image.
I know that I could use 3 relays to (1) reverse polarity (2) constant pos. to pulse (3) reverse polarity again to neg.
There has to be an easier way to accomplish this. Is there a way to rewire the relay above to receive and output neg signals?
Input?
Platinum - Posts: 13,725
Posted: February 21, 2009 at 2:48 AM / IP Logged
lexelite
Copper - Posts: 82
Posted: February 21, 2009 at 9:08 AM / IP Logged
Thanks!!! I will now be able to integrate this relay into my larger relay diagram for my TPS exhaust valves.
12vlost
Member - Posts: 44
Posted: March 31, 2009 at 1:50 PM / IP Logged
Hi, how will I wire a relay to acheive mom neg to constant neg?
TIA
Posted: April 01, 2009 at 2:43 PM / IP Logged
Look at the relay section here or the Maplin Catalogue for latched relays.
