wire dual voice coil sub
walkerhounds23
Member - Posts: 10
Posted: March 06, 2009 at 6:36 PM / IP Logged
how do i wire my ten inch aw1006t audiobahn dual voice coil sub to my sony explode 1200 watt channel amp. so it is bridged.? in 2 ohms or greater. ive never had to wire a sub that has 4 connections on it and im lost.
walkerhounds23
Member - Posts: 10
Posted: March 06, 2009 at 6:42 PM / IP Logged
and would a dual ported box sound good with this sub? i found one on ebay
stevdart
Platinum - Posts: 5,816
Posted: March 06, 2009 at 6:58 PM / IP Logged
Two voice coils, each one is 4 ohms.  Each one has two inputs, mainly so that in rare situations someone might want to insert PHAT wires into every one of them for that PHAT WIRY look.  But only one + and - on each coil needs to be used...using both is called "parallel wiring" and changes impedance factor.
So use just one input at each coil.  Here's a page from crutchfield.com  They show you the manufacturer's ported box requirements on that page.  A dual ported box would have to have ports the same diameter but twice as long as what you see on that page, and therefore a larger overall box size.  Keep it one port and as close to the 1.4 cu ft per sub spec as possible.  Best thing to do is have somebody build a box for you.
walkerhounds23
Member - Posts: 10
Posted: March 06, 2009 at 7:02 PM / IP Logged
thanks alot i appreciate the information. it was very helpful. any sugestions for a box?
walkerhounds23
Member - Posts: 10
Posted: March 06, 2009 at 7:05 PM / IP Logged
oh nevermind i see. it says about wat box to use
stevdart
Posted: March 06, 2009 at 7:07 PM / IP Logged
I was editing/ adding so there's a bit more info in my last post.  Good luck with your setup.
soundnsecurity
Gold - Posts: 2,720
Posted: March 06, 2009 at 11:38 PM / IP Logged
wow. 2 posts about wiring an audiobahn sub in one day. what are the odds?
haemphyst
Platinum - Posts: 5,059
Posted: March 07, 2009 at 12:37 AM / IP Logged
Unfortunately, a little too good...
