93 lexus sc300 headunit
aflak08
Posted: March 13, 2009 at 11:47 AM / IP Logged
I've been installing a Pyle PLTSD7BT and oh my is the sc300 stereo confusing! It just won't [COLOR="Black"]turn on[/COLOR]. Ive been using this diagram because its the only one that matches my stock system and its color coded as well: http://web.ukonline.co.uk/soarertt/i...diagram_03.jpg
I'm not sure about what to plug into the "ground". Right now its wrapped around a screw on a metal surface under the shifter. I figured my problem is probably with the memory battery or ACC wires.
Currently I have it wired like this ((not working)):
Yellow (battery anode +12v): +B plug
Red (12v ACC/Right+): Acc plug
Grey (Amplifier power control line): None
Black (ground): wrapped around metal screw
Blue (power antenna): P/Green and P/BLue wires
Pink (Braking line): None
I saw somewhere that someone had a 12v amp hooked in the memory battery place and that there is a wire for the braking line under the shifter. I don't know if not having the brake wire in could be keeping it from turning on. Could someone take a look at that diagram and tell me what I am doing wrong and what I should have hooked where? I just want it to turn on!
A HUGE thanks in advance
((sorry for making this so long. Just wanted to make sure I covered everything))
aflak08
Posted: March 13, 2009 at 2:24 PM / IP Logged
