2001 Hyundai Tiburon-start and locks
jimijames8050
Posted: March 22, 2003 at 8:59 AM / IP Logged
Does anybody have wiring info for a 2001 Tiburon (does not have the factory keyless)? Looking to install remote start and locks.
Thanks.
Platinum - Posts: 12,488
Posted: March 22, 2003 at 9:12 AM / IP Logged
|              12V|yel/blk to blue     |+  |ignition harness            |
|          STARTER|yel/red to gray     |+  |ignition harness            |
|         IGNITION|blk/wht to brown    |+  |ignition harness            |
|        ACCESSORY|RED / wht to grn/wht  |+  |ignition harness            |
| SECOND ACCESSORY|wht/blu to pink     |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in drivers door             |
|     POWER UNLOCK|same                |   |                            |
| PARKING LIGHTS +|GREEN / WHITE         |   |gray 20 pin plug, pin 11 *2 |
| PARKING LIGHTS -|RED / black           |   |headlight switch            |
|       HEADLIGHTS|blue/black          |-  |headlight switch            |
|     DOOR TRIGGER|GREEN / WHITE         |-  |white 20 pin plug, pin 12 *3|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|blue/white          |-  |white 20 pin plug, pin 16 *3|
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|white               |   |blue 20 pin plug, pin 1 *5  |
|      SPEED SENSE|yellow/black        |   |data link connector *1      |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|pink/white          |-  |steering column             |
|           WIPERS|red (L), green (H)  |-  |steering column * 4         |
|  LF WINDOW UP/DN|blue - brn/blk      |A  |drivers window switch       |
|  RF WINDOW UP/DN|blue - brn/blk      |A  |passengers window switch    |
| SUN RF OPN/CLOSE|yel/blu - blue      |A  |sunroof motor               |
|        RADIO 12V|RED / white           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|orange              |+  |radio                       |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|       LF SPEAKER|yellow - black      |   |radio                       |
|       RF SPEAKER|orange - green      |   |radio                       |
|       LR SPEAKER|brown - white       |   |radio                       |
|       RR SPEAKER|white - brown       |   |radio                       |
Notes:
*1 The data link connector is under the driver side dash below the steering column.  *2 The plug is below the cross member beam under the driver side dash.  *3 The plug is high in the drivers kick panel.  *4 These wires are high current negative.  *5 The plug is just below the cross member beam under the driver side dash. Can also find tach at the ignition coil on the driver side of the engine, use either the green or white wire.
jimijames8050
Posted: March 22, 2003 at 9:19 AM / IP Logged
wow, that was fast... Thanks!
Posted: March 22, 2003 at 7:01 PM / IP Logged
No problemo
