wire primary/secondary switch
absolutalchemy
Member - Posts: 9
Posted: April 26, 2009 at 10:23 PM / IP Logged
I'm looking to use a SPDT rocker switch ON/OFF/ON to allow me to have one switch that has Primary ( all led lights ) and Secondary ( rear led lights only ). I am planning to run the front 2 led lights to one side of the switch and the rear 2 led lights to the other side of the switch. Then use a rectifier diode to bridge from the one side to the other, so when I switch to secondary only the rear turns on, and when flipped to primary the front comes on and diode also allows power to rear so they come on as well. Is this a proper way to do this? Any thoughts or comments would be great. Thanks
absolutalchemy
Member - Posts: 9
Posted: April 26, 2009 at 10:24 PM / IP Logged
BTW its for an 05 ford F 150, thanks
KPierson
Platinum - Posts: 3,527
Posted: April 27, 2009 at 8:38 AM / IP Logged
Yes, that would work as long as the diode has enough current capacity.  If you are only running to small LEDs then it won't be a problem - a 1A diode will work.
If you plan to pull a decent amount of current through the switch you will need to keep the same conept but use relays.  You can diode isolate the relays so that it works the same way you described above, but since you are only switching a relay you can keep the small 1A diode.
Kevin Pierson
absolutalchemy
Member - Posts: 9
Posted: April 27, 2009 at 9:32 AM / IP Logged
the front leds are total of about 2 amps and the rear is about 2 amps as well, the diode I was looking at is:
Ultrafast Rectifier Diode
Dual Common Cathode
30 Amp
600V
50ns
IS that one ok?
KPierson
Posted: April 27, 2009 at 10:28 AM / IP Logged
That's a pretty big diode, but it should work.
Kevin Pierson
Platinum - Posts: 13,725
Posted: April 27, 2009 at 3:40 PM / IP Logged
Physically, how big is that diode?
absolutalchemy
Member - Posts: 9
Posted: April 27, 2009 at 7:19 PM / IP Logged
Its 1.65 inches long, .645 inches wide, and .203 inches high
Is there a smaller one I can use that will work as well?
Posted: April 27, 2009 at 7:56 PM / IP Logged
Yes, radio shack sells a 6 amp diode.  It is much smaller than the one you posted dimensions for.
wire primary/secondary switch - Last Post -- posted image.< color=#0052b4>
< color=#0052b4>wire primary/secondary switch - Last Post -- posted image. wire primary/secondary switch - Last Post -- posted image.< color=#0052b4> Print < color=#0052b4>wire primary/secondary switch - Last Post -- posted image. wire primary/secondary switch - Last Post -- posted image.< color=#0052b4> wire primary/secondary switch - Last Post -- posted image.< color=#0052b4> Email a friend < color=#0052b4>wire primary/secondary switch - Last Post -- posted image.< color=#0052b4> < color=#0052b4>wire primary/secondary switch - Last Post -- posted image.
< color=#cc0000 >6A, 50V Rectifier Diodes (4-Pack)
< color=#2a2a2a>< class=ourprice>$2.49
< color=#2a2a2a >wire primary/secondary switch - Last Post -- posted image.Model: 276-1661
Catalog #: 276-1661
Online: wire primary/secondary switch - Last Post -- posted image. In stock
Usually ships in 1 - 2 business days < ="return verifyFields('no',.order);" method=post name=order =/cartHandler/index.jsp>< value=skuAddToCart = name=> < = name=wlName> < value=2032058.2032230.2032269 = name=cp> < = name=showMy> < value=1 = name=qty_0>
Disregard the text about relays on this picture.  It was intended for using one switch for parking lights and headlights.
absolutalchemy
Member - Posts: 9
Posted: April 28, 2009 at 7:46 AM / IP Logged
thanks for the help, ill let you know how it goes
