sub wiring, 2 d4's and 1 d2 woofer
vandal337
Member - Posts: 11
Posted: April 29, 2009 at 3:57 PM / IP Logged
looking to run 1 ohm stable. is it possible to wire 2 d4's and 1 d2 woofer (series parallel) without destroying anything?
Vandal337
vandal337
Member - Posts: 11
Posted: April 29, 2009 at 3:59 PM / IP Logged
2 ts-w3001d4's and 1 ts-w3001d2 all premieres
Vandal337
djrankin004
Copper - Posts: 154
Posted: April 29, 2009 at 6:04 PM / IP Logged
what kinda amp will you be running this to? mono>?
stevdart
Platinum - Posts: 5,816
Posted: April 29, 2009 at 10:21 PM / IP Logged
Here's a recent post that's similar.  See especially i am an idiot's reply at the end.
Here's a way you can achieve equal power distribution to all 3 subs:
sub wiring, 2 d4's and 1 d2 woofer - Last Post -- posted image.
The left and middle are the d4's.  The one on the right is the d2.  Both coils on the d2 are used, while only one coil on each of the 4's is used.  The d2 is series-wired to make a 4 ohm impedance, and then the three 4 ohm impedances are paralleled to achieve an equally distributed 1.33 ohm load on the amp.
To see if single coils can be used in your situation, determine the power output of the amp (RMS) at 1.33 ohms (which will be less than at 1 ohm).  Find the continuous power handling capability of each of the subs, then add the three of them together.  Find 2/3 of that capability.  If it is about equal to or more than the amp's true output then the situation will be safe.
Example:  each sub is rated 500 watts continuous, both coils driven (1500 watts total).  2/3 of the sum total would be 1000 watts.  If the amp puts out about 1000 RMS watts or less at 1.33 ohms it is a safe situation to use only one coil per sub.
Platinum - Posts: 13,726
Posted: April 30, 2009 at 4:14 AM / IP Logged
Just in case you didn't notice that the word post was blue, (as it eluded me at first) Here is the link he was talking about.
vandal337
Member - Posts: 11
Posted: April 30, 2009 at 1:49 PM / IP Logged
thanks thats exactly the info i needed thanks >stevdart<
Vandal337
vandal337
Member - Posts: 11
Posted: April 30, 2009 at 1:53 PM / IP Logged
MA Audio HK200D
Vandal337
