voltage regulator, leds
livehho
Member - Posts: 17
Posted: May 13, 2009 at 5:09 PM / IP Logged
do I need a separate voltage regulator for each LED ?
KPierson
Platinum - Posts: 3,527
Posted: May 14, 2009 at 5:25 AM / IP Logged
You need to find out what the current draw is.  Since they are designed to run at 12vdc you can assume they have a current limiting resistor built in to them.  I would assume the current would be less then 30mA for each LED.  That would allow you to run ~20 of them off of a 1A 7805 as long as you use a heat sink on the 7805 (or just bolt it to a large metal part of the car).
Why are you going with a flashing LED?  That might look funny when they all flash at different rates due to the fact the flashing is internally controlled.
Kevin Pierson
livehho
Member - Posts: 17
Posted: May 14, 2009 at 1:44 PM / IP Logged
cool thanks.. I'll find out what current they work with
only two of them will flash.. the others won't
i'm installing a water injection system.. as well a hydroxy generator
livehho
Member - Posts: 17
Posted: June 07, 2009 at 7:03 PM / IP Logged
KPierson wrote:
The LM2937 is a great regulator for automotive use, but is overkill in your situation.  A typical 7805 will work fine and provide years and years of troublefree service in an automotive environment (if used correctly).
What the LM2937 offers that the 7805 doesn't is a low drop out voltage (completely irrelevent to your application) and low quiescent current (again completely irrelevent to your application).
The drop out voltage is how much higher the input has to be then the output for the output to stay regulated.  Typically, in a car, you go with a 5vdc output so as long as you have more then 7vdc on the input (ie battery) the 7805 will be fine.  The quiescent current is how much current the regulator itself needs to operate.  Since you won't be leaving your dash lights on for extended periods when the car isn't running a few extra mA (typically 6-8mA) of current draw isn't going to hurt you.
With any voltage regulator the proper procedure for running it is to select the component (say a National Semiconductor LM2937ET-5.0/NOPB) and then download that specific data sheet ( http://www.national.com/ds/LM/LM2937.pdf).  If you look at page 8 of that data sheet it will show you the typical application - follow that diagram and the recomendations closely and you''ll get great results.
The LM2937 has special considerations due to it's low drop out design and the capacitor calculations can be cumbersome (especially in colder environments).  Unlike the 7805 if you don't have the correct capacitance on the LLM2937 the output can oscilate and damage whatever is hooked up to it.  The colder the climate the more capacitance you will need to prevent the oscilation.
Hi Kevin.. first I want to thank you for your great help on previous posts here.. i have leaned a lot. I was looking at http://www.fairchildsemi.com/ds/LM/LM7805.pdf as per your suggestion and on page 22 says to use an input cap of 0.33 mF and an output cap of 0.1 mF
Do you think these capacitors will work for any output voltage I chose? will these capacitor values work fine for 5V or 12V output voltage?
livehho
Member - Posts: 17
Posted: June 07, 2009 at 7:05 PM / IP Logged
I've chosen to work with 12V instead of 5V output
KPierson
Posted: June 07, 2009 at 7:31 PM / IP Logged
The most important thing to do when working with voltage regulators is to make sure you follow the instructions in the data sheet for the exact regulator you are using.  Different manufacturers will spec out different components for similar part numbers (ie a Fairchild 7805 may need certain capacitors and a National 7805 may require different caps).
If you are going to go with a 7812 just make sure you order the part that relates to the data sheet and you'll be fine.
Kevin Pierson
livehho
Member - Posts: 17
Posted: June 07, 2009 at 8:48 PM / IP Logged
cool. thanks a lot kevin.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
