box for 98 ford explorer
bud howard
Posted: May 27, 2009 at 6:58 PM / IP Logged
need some on a box for my 98 explorer i have 41''w-18''tall-20''deep--i have 2-15''crystal cmpx215 subs and need some help with the box i have never done a ported box would like to do 4'' pvc pipe and tune to 26hz to 30hz any help would be nice---just let me no if you can help me out--if it helps i am runing a orion-2100hcca on ea sub--what  will be the best box for my set up
if it ant shakeing you got taken
vibrationcustum
Copper - Posts: 171
Posted: June 22, 2009 at 2:22 PM / IP Logged
is the pvc 4" outer or inner diameter. If you use all of the space you have gave us you will have 6.1 ft^3 inside with a 3" square port tuned to 27hz. Nice and easy to make if you want to go with the square port instead of the 4" pvc. If so then I will send you the specs to build the box.
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
aznboi3644
Gold - Posts: 2,600
Posted: June 22, 2009 at 9:32 PM / IP Logged
For those subs I would use two 6" round ports atleast if you can.
The enclosure would be around 7 cu ft NET after port and sub displacement...I can get you balls loud
Custom Enclosure Design
