1995 chevy caprice remote start problem
dukesacc
Posted: May 30, 2009 at 8:17 AM / IP Logged
I had an Black widow security system installed in my vehicle about a year ago. the problem i am having is that some times the remote start does not start the vehicle, it just click(one time) like its going to start but does not start. But when i turn the key inside the vehicle to on position, then try to remote start it, it starts. Another problem i am having  is that when it does start, the system work properly until the ac/heater engages then the power wire to the remote start sys. gets hot and some times blow the fuse. Any suggestions?
http://www.blackwidowsecurity.com/z5.htm
cd
tommy...
Gold - Posts: 1,901
Posted: May 30, 2009 at 8:44 AM / IP Logged
It sounds like its time to take it back to the shop. Most units have limited lifetime warranties. When it does attempt to start...do all lights on the dash come on...It just doesnt crank...?
1995 chevy caprice remote start problem - Last Post -- posted image.BatteryRED(+)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Ignition 2BROWN(+)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Anti-Theft TypeRESISTOR BASED SYS
1995 chevy caprice remote start problem - Last Post -- posted image.Anti-Theft DescriptPASSKEY
1995 chevy caprice remote start problem - Last Post -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
1995 chevy caprice remote start problem - Last Post -- posted image.Neutral SafetyORANGE / BLACK(-)AT GEAR SELECT SWITCH
1995 chevy caprice remote start problem - Last Post -- posted image.TachometerWHITE(-)OR VIO/WHT(-) AT COIL V8 OR MULTI COIL V
1995 chevy caprice remote start problem - Last Post -- posted image.Speed SenseGREEN / WHITE(AC)UNDER AIR CLEANER BLK CONN POS B-8
1995 chevy caprice remote start problem - Last Post -- posted image.Parking LightsBROWN(+)AT LIGHT SWITCH
1995 chevy caprice remote start problem - Last Post -- posted image.Brake LightsWHITE(+)AT BRAKE SWITCH
1995 chevy caprice remote start problem - Last Post -- posted image.Reverse LightsLIGHT GREEN(+)AT GEAR SELECT SWITCH
1995 chevy caprice remote start problem - Last Post -- posted image.HornBLACK(-)AT STEERING COLUMN
M.E.C.P & First-Class
dukesacc
Posted: May 30, 2009 at 9:13 AM / IP Logged
Yes all the lights come on just does not start
cd
tommy...
Gold - Posts: 1,901
Posted: May 30, 2009 at 3:33 PM / IP Logged
Check starter wire...Check power on both 12v wires...Check By-pass...That does have the little silver chip in the key...? It sounds like an issue w/ the bypass...If the Accessory wire is getting warm...Probably dis-connect untill you get it repaired...! I would really take it back to the shop who installed it...! I know some manufacture gives you alternate wiring for accessory if system pulls to much current then the remote start can handle...
