cant get my amp to work
rub8322
Member - Posts: 18
Posted: June 02, 2009 at 9:36 PM / IP Logged
i am an idiot wrote:
Does your radio or amplifier have a built in crossover?   On the amp it will be a switch with these settings.  LPF/FULL/HPF
i think it does, the amp has three or four small knobs and those letter are very familiar, i think i saw them on the amp.
Platinum - Posts: 13,726
Posted: June 02, 2009 at 11:08 PM / IP Logged
LPF = Low Pass Filter, it only allows low frequencies to pass through the amp.
HPF = High Pass Filter, it only allows higher frequencies to pass
FULL = Full Range, it allows all frequencies to pass.
rub8322
Member - Posts: 18
Posted: June 03, 2009 at 2:53 AM / IP Logged
so which one should i turn off to get rid of the voices? is there a specific setting i should have to get the best quality bass.
Posted: June 03, 2009 at 5:39 AM / IP Logged
Some amps are different, you may have to try it in each position and see what works best for your amplifier.   There may be a knob very near that switch also.  It may be labeled Crossover Frequency, after you figure out which switch position works best for you, you may want to give that knob a twist and see what it does.
rub8322
Member - Posts: 18
Posted: June 03, 2009 at 3:28 PM / IP Logged
ok, i will post more info on what happened. thanks
