2009 Dodge Ram Stereo Wiring
tommy...
Gold - Posts: 1,901
Posted: June 11, 2009 at 9:41 AM / IP Logged
There is also a tool you can buy...Point towards speaker and will tell you if polarity is correct...Might be a good investment if you see yourself doing more/other stuff...Otherwise the post from velocity will work great...
M.E.C.P & First-Class
KarTuneMan
Platinum - Posts: 7,056
Posted: June 11, 2009 at 7:34 PM / IP Logged
I bought one of those tools..... it's a mostly dead 9v battery.   mostly? is that a real word?
I attached an old set of DMM leads to it....
Platinum - Posts: 13,725
Posted: June 11, 2009 at 7:42 PM / IP Logged
If you can not see the driver through the grill and you do not want to remove the panel, it may be possible to push a straw from a broom through the grill until it touches the cone of the speaker, hold it gently and have some one pop the wires with the battery.  You should be able to tell which way the cone is moving.
