Wiring to attain 2Ohm load?
Bio-Surge
Posted: March 25, 2003 at 6:47 AM / IP Logged
Hi there.
I'm a newbie and would just like to clarify something in my mind.
I have 2 sets of Polk DX3065 (Problem with living in a 3rd world country) splits that I would like to drive with an Audison LRX 4.300 amplifier. Now the amplifier's rating at 4Ohm is 65W x 4, and at 2Ohm it's 105W x 4. Now as far as I understand things if I just hook up the splits seperately on a channel I'll get 65W x 4 pushed to my splits. Now is there a way of wiring up the splits to get to the 105W 2Ohm output? Or will I need to re-evaluate my choice in amplifier?
Thanks in advance.
Bio-Surge
Posted: March 25, 2003 at 6:52 AM / IP Logged
Sorry forgot to add that I'd like to still have each set of splits on a seperate channel. ie. Front left/right & Rear left/right.
Hope you guys can help.
Powerslave0
Copper - Posts: 116
Posted: March 25, 2003 at 7:06 AM / IP Logged
You have to take both 4-Ohm speakers and wire them in Parallel to obtain the 2-Ohm load.
Wire the positive from the AMP to one speaker, then run another wire from that positive to the other speaker's Positive, and do the same with the Negative's. That is how you wire in Parellel.
Bio-Surge
Posted: March 25, 2003 at 7:34 AM / IP Logged
Thing is the splits have a passive crossover (forgot to mention) so it would be impossable to drop to 2Ohm while using the passive crossovers?
Thanks to the reply.
Powerslave0
Copper - Posts: 116
Posted: March 25, 2003 at 2:13 PM / IP Logged
You should wire the Cross-over +/- wires directly to the +/- terminals of the Amp. Then, out of the cross-over to the speakers as described + to + in a line, then - to -. This is still a 2ohm load to the amp. If the cross-over has ANY impedance, this may mess you up, but usually a passive should not add any. . .
Bio-Surge
Posted: March 25, 2003 at 10:47 PM / IP Logged
I was hoping something like that would work... Thanks a stack for the help.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
