what ohm load would this produce?
jerad73
Posted: June 07, 2009 at 8:11 PM / IP Logged
4 subs, 4ohm single voice coil.
all 4 positive wires are connected to the positive terminal on the cup
all 4 negative wires are connected to the negative terminal on the cup.
would this make a 1ohm or 4 ohm load?
Platinum - Posts: 13,726
Posted: June 07, 2009 at 8:17 PM / IP Logged
Four 4 ohm Single Voice Coil (SVC) Speakers
Option 1 (parallel) = 1 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono
what ohm load would this produce? - Last Post -- posted image.
Option 2 (series/parallel) = 4 ohm load
Two pair of speakers, each pair wired in series, then wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
ben_c_8
Member - Posts: 13
Posted: June 08, 2009 at 1:52 PM / IP Logged
yes the loads add together, two single 4 ohm would be 2 ohm...3 will be an off number, and four will be one.
Ben carnes-2ma hk15x2 + 5500d
haemphyst
Platinum - Posts: 5,059
Posted: June 08, 2009 at 3:36 PM / IP Logged
ben_c_8 wrote:
...3 will be an off number...
It's a technical term... VERY industry specific.
ben_c_8, they don't add together, except in series. He is asking about parallel. "Impedance of each voice coil divided by the number of voice coils". That's not additive.
Posted: June 08, 2009 at 4:44 PM / IP Logged
The "off number" would be 1.33
https://www.the12volt.com/caraudio/woofer_configurations.asp
https://www.the12volt.com/caraudio/boxcalcs.asp   Scroll down a bit and there are a series and a parallel calculator.
