Posted: June 12, 2009 at 2:31 PM / IP Logged
Posted: June 12, 2009 at 9:11 PM / IP Logged
Posted: June 13, 2009 at 1:48 AM / IP Logged
Posted: June 13, 2009 at 2:03 AM / IP Logged
Posted: June 13, 2009 at 6:30 AM / IP Logged
Posted: June 13, 2009 at 6:35 AM / IP Logged
Monday, March 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I understand where the 56a and 56b (I think it says b!) must connect to - one to the fog light relay and one should be empty (for off).
This leaves 56, 30 and S - one must be a permanent 12v (I can grab this from the 12v into the switch) would this be 56? One must be the output from the switch (either 30 or S)... is the other earth? I cannot understand from the diagram how 30 and S work!
Any help you can offer would be hugely appreciated!
Thanks,
Gareth
Does this make any difference to the way you suggest wiring it up for the purposes of my fog light? Should I go with the same pins?
Thanks,
Gareth
