true or false amp mount?
ceasar326
Copper - Posts: 239
Posted: June 17, 2009 at 4:50 PM / IP Logged
So ive always screw the amps on the trunk, specially when there fold down seats there really easy. But this time ive got a chevy impala ss 96. So i got all the stuff working properly subs, head unit, and speakers. Next day he takes it to a diffrent shop to get his window tint done, and I guess they told him that the amp cannot be mounted to metal witch is the back seat. First time hearing that whanted to make sure its true
true or false amp mount? - Last Post -- posted image.
soundnsecurity
Gold - Posts: 2,720
Posted: June 17, 2009 at 5:47 PM / IP Logged
ive never heard of that either
icearrow6
Copper - Posts: 497
Posted: June 17, 2009 at 7:27 PM / IP Logged
The only situation I've encountered was when the amp was bolted on the sheet metal of the car causing a ground loop (engine noise). Other than that, no problems.
Platinum - Posts: 13,726
Posted: June 17, 2009 at 7:35 PM / IP Logged
As stated above, there were some older amps that would give you noise problems if mounted to the chassis of the car.  However they all put rubber grommets on the mounting holes so the screw or the chassis of the vehicle were not allowed to touch the chassis of the amp.  Linear Power is the only brand that I can think of right now.  There were several others.  These were all from the 80s.  Lately I have not seen any amp that was not to be mounted to the chassis of the vehicle.
aznboi3644
Gold - Posts: 2,600
Posted: June 17, 2009 at 7:53 PM / IP Logged
"sometimes" it can introduce noise...other than that there is nothing wrong with it.
Peepole argh idiots...plane and simpole.
Custom Enclosure Design
