back up camera not working with z3
yunginstaller
Member - Posts: 12
Posted: July 01, 2009 at 7:51 AM / IP Logged
i put a pioneer z3 in a 2005 magnum. i hook up the back up camera and it really dark. so i plug the rca from the camera into the video in feed, and its perfect. i hook it up to a z2 in my car and it works fine on the reverse camera input as normal. so then i took the harness from mine that has the reverse camera input that i know works fine and switched it with the z3 and i still have the same problem. cant fiqure it out and the car has to leave saturday. could the headunit be bad?
joch1314
Copper - Posts: 301
Posted: July 01, 2009 at 12:45 PM / IP Logged
Did you select the proper input signal for the reverse light?  Most cars will give a positive signal when you go into reverse, but some will give a ground signal.  The deck needs to see the proper signal to turn on the back-up camera.  Where did you get you reverse wire?
...half of the truth can be worse than a lie. <----Roger Russell said that..
yunginstaller
Member - Posts: 12
Posted: July 01, 2009 at 12:53 PM / IP Logged
yes i originally had it hooked up the the (+) reverse signal from my headunit harness. but im still having the problem after i disconnect it and hook up both the positive from the camera box and the reverse wire to a battery charger. and yes my headunit is in the positive polarity mode.
sidewinder01
Posted: July 07, 2009 at 11:34 PM / IP Logged
Check the setting of the head unit, it may be set to pal, switch it to ntsc
FrAncIscO
yunginstaller
Member - Posts: 12
Posted: July 13, 2009 at 1:20 PM / IP Logged
how would i do that
sidewinder01
Posted: July 13, 2009 at 2:15 PM / IP Logged
go to the setting of the monitor then system setting you can see ntsc, pal, or secam, since you are in the united states the system there is ntsc, so select ntsc.
FrAncIscO
