2002 nissan sentra spec v
skwearl
Member - Posts: 20
Posted: July 07, 2009 at 10:35 AM / IP Logged
I am looking for stereo wiring information on a 2002 nissan sentra Spec - V with the 7 speaker sound system.
Thank you
t&t tech
Platinum - Posts: 2,622
Posted: July 07, 2009 at 5:46 PM / IP Logged
i've done alot of sentras, but never one with seven speakers i don't know if the wiring is different but i'll give you what i can remmember from my head,
accesory-pink. twelve permanent- blue, power antenna- BLACK/ white, parking lights- RED / blue,
speakers i can't remember which is which but when you peel of the rubber insulation on the harness you can test to verify, the wires are GREEN/ YELLOW and purple, brown and BROWN / white, grey and grey/red, BLACK/ pink and orange, that's four speakers, sorry if this doesn't help you but these are the sentras i'm accustomed to.
yimke
Copper - Posts: 417
Posted: July 07, 2009 at 6:33 PM / IP Logged
|        RADIO 12V|blue |+ |at radio     |
|     RADIO GROUND|     |   |             |
|     RADIO SWITCH|pink |+ |at radio     |
| RADIO ILLUMINATE|yellow/red          |+ |at radio     |
|       LF SPEAKER|purple - grn/yel    |   |at radio     |
|       RF SPEAKER|brown - brn/wht     |   |at radio     |
|       LR SPEAKER|orange - blk/pnk    |   |at radio     |
|       RR SPEAKER|gray - gry/red      |   |at radio     |
These colors will change for the speakers though because I think you have the premium package system. There will more than likely be another +- speaker lead for the sub if there is one.
What type of system is it Rockford??
I would probably recommend this if you are doing a radio install for the rockford system.
70-7551
http://www.installer.com/item/display_item.php?it=70-7551
and
4 ch line output/noise filter in case of any pop/engine noise
http://www.bestbuy.com/site/olspage.jsp?skuId=8014659&st=isve+61&lp=1&type=product&cp=1&id=1156203597652
yimke
Copper - Posts: 417
Posted: July 07, 2009 at 6:34 PM / IP Logged
Also the wiring for the speakers will be incorrect if it is the rockford system, because it is common ground.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
