bose speakers and amp, 2004 nissan altima
bigvon
Posted: July 07, 2009 at 7:18 AM / IP Logged
I'm taking the bose radio out of my nissian altima( stop playing CD'S and will not show anthing about the cd player on the screen)so I'm installing an 7" touch screen mobile DVD,CD deck I've hooked up the deck but i get no sound can someone help me PLEASE ! can i still use the BOSE  speakers I want to try to keep the Bose amp to run the BOSE speakers is that possible?
bigvon
Posted: July 08, 2009 at 6:35 AM / IP Logged
For a 2004 nissian altima when taking out the factory bose 6disc/radio and adding an 7''dvd/cd touch screen flip out to get sound out ouf the bose speakers do you unhook the bose amp or is there a way to use the bose amp for the bose speakers in the car.
yimke
Copper - Posts: 417
Posted: July 08, 2009 at 7:02 PM / IP Logged
Did you hook up the blue/white wire on the female harness?
Also if you get any pop/hiss/alt noise I would recommend a 4 ch LOC/noise filter.
ajstetler
Copper - Posts: 94
Posted: July 08, 2009 at 8:36 PM / IP Logged
You may need to solder rca ends to your wire harness. A lot of Bose systems uses low level input. If you wire as normal and turn it up a few clicks and it gets really loud fast, you need to send a low level signal instead.
Big Al
bigvon
Posted: July 09, 2009 at 1:52 PM / IP Logged
Slice into the factory bose amp wire and connect the blu/wht wire comming from the new harness to the bose amp harness?
the12volt
Administrator - Posts: 3,959
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
