wiring and headrest
bigvon
Posted: July 09, 2009 at 6:47 AM / IP Logged
I'm looking for 2 things the 1st is the imformatiom for wiring system stereo/amp  bose system  for the nissian altima 2004 LS.........
2nd,I need information on how to hook up two headrest monitors in the nissian 2004altima LS the head rest that I have are XOvision and it has an red wire and blk wire with the rca jack hook ups how do i hook this in to my 7''touch screen fip out cd/dvd deck.
t&t tech
Platinum - Posts: 2,622
Posted: July 09, 2009 at 4:29 PM / IP Logged
i can't help you with the altima wiring but i can with the screens, ground both black leads from the head rests, and the other two red leads go the remote wire of the head unit, it would be advisable to boost the head unit's signal with a relay.
The rca inputs, if the screens have speakers in them then run a pair of rca's to both screens, the yellow input would be the video input and you red and white would be audio. the video input would plug into the video output to the back of your head unit. the same for your audio jacks, to the audio output from the back of the unit.
icearrow6
Copper - Posts: 497
Posted: July 09, 2009 at 4:38 PM / IP Logged
Do you want to keep the factory bose amp? If so you need to purchase the amp integration harness from your local shop.
Otherwise the factory amp is located in the trunk at the rear deck.
These are standard nissan wiring colors. easy bypass.
Posted: July 10, 2009 at 1:19 AM / IP Logged
Loved icearrows bottom quote, I tell them the installation's free but my knowledge isn't.
the12volt
Administrator - Posts: 3,957
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
