Posted: July 23, 2009 at 7:49 PM / IP Logged
Posted: July 24, 2009 at 9:53 AM / IP Logged
Posted: July 24, 2009 at 9:54 PM / IP Logged
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
What do you think? I also changed the red wire to the accessory wire from the ignition switch, same effect. Do you think the ground wire should be changed to the chassis?
Also I read in other posts about a ground on pin 19. Should I ground that wire?
I am unfamiliar with this module since we do not stock it. There is a blue / YELLOW wire next to the direct plug in. What does that do?
