08 jeep wrangler remote starter?
kenmoore
Posted: July 31, 2009 at 9:40 PM / IP Logged
We have a 2008 jeep wrangler I want to put a remote starter on.  does anyone have the wiring schematics?  can anyone explain to me about the negative triggered starter input???  Any help is greatly appreciated.
big ken
t&t tech
Platinum - Posts: 2,622
Posted: August 01, 2009 at 10:10 AM / IP Logged
this is for an 08. double check with a meter......
Make:   Jeep
Model: Wrangler
Year:    2007
This Database Was Last Updated On:    7/3/2007
Index #: 7414
Alarm
Constant 12 volts RED / BLUE IN PASSENGERS KICK PANEL
Ignition 12 volts PINK/WHITE AT IGNITION SWITCH
Starter PURPLE / BROWN (MUX) AT IGNITION SWITCH
Dome Light SEE DOORS IN TECH
Trunk Pin Switch PURPLE / ORANGE IN PASSENGER KICK LARGE HARNESS
Parking Lamp WHITE/ PURPLE IN PASSENGER KICK LARGE HARNESS
Power Lock PURPLE / GREEN DRIVERS KICK PANEL 1K RESISTOR #217
Power Unlock PURPLE / GREEN DRIVERS KICK PANEL 180 OHM RESISTOR
#217- See Single Wire Resistor Door Lock Diagram (+).
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
