led triggered by dome light and on/off/on
jewster
Member - Posts: 14
Posted: December 17, 2009 at 11:28 AM / IP Logged
Although that circuit is simpler for omitting the relay, I think I will go with the relay instead. This is becuase I will likely add LEDs to this circuit, but in other locations and having the power source and dome light trigger junctioned for additional circuits would be more convenient than running more wire all over the place.
Is there any real drawback to using a relay here?
KPierson
Platinum - Posts: 3,527
Posted: December 17, 2009 at 3:23 PM / IP Logged
Sorry about the fuse being in the wrong place, I just copy and pasted your diagram and hacked it up a bit.
There isn't a drawback, we just like to keep things simple and not use parts if they are not necesarry.
Kevin Pierson
jewster
Member - Posts: 14
Posted: December 17, 2009 at 3:30 PM / IP Logged
Okay, that is what I thought. Thanks very much again for the help.
petertfm
Posted: January 24, 2010 at 12:46 PM / IP Logged
Hi I am new here but I was searching for this exact solution.
I have wired my 2002 sunfire just like the diagram from jewster made
without the switch, but the problem is when the dome light dims at the end my relay buzzes.
my question is"is there a transistor or something I can put in the circuit to fix this?"
maybe a transistor connected to dome light ground that can trigger the relay
that transistor would have to be able to work under low voltage and up to 12 or 14 volts
any help would be greatly appreciated.
oldspark
Gold - Posts: 4,913
Posted: January 24, 2010 at 7:48 PM / IP Logged
Exactly.
If they are LEDs, do not use the relay - it is not needed.
Otherwise you could use a transistor with a current capability sufficient for the load (lights). In this case it would be a PNP. A FET may also be suitable - especially for dimming.
The circuit depends on whether full brightness or dimming.
petertfm
Posted: January 25, 2010 at 6:59 PM / IP Logged
I found a solution to the relay buzzing
https://www.the12volt.com/installbay/forum_posts.asp~TID~114184~get~last#585248
I just didn't want to run any thing extra on the circuit for the dome light. and I also plan on adding more to the circuit for my leds
oldspark
Gold - Posts: 4,913
Posted: January 25, 2010 at 7:14 PM / IP Logged
But that might blow the dimming circuit (if it can't handle the cap current).
Besides, why the heck use a relay if it is for LEDs?
97accord
Member - Posts: 17
Posted: April 17, 2010 at 8:00 PM / IP Logged
does anyone know what does the dot's mean
that kpierson draw
KPierson
Posted: April 17, 2010 at 8:16 PM / IP Logged
What dots?
Kevin Pierson
oldspark
Gold - Posts: 4,913
Posted: April 17, 2010 at 10:01 PM / IP Logged
The only dots I see are the symbolic contacts - ie, switch contacts.
Also, if the wiring is done similar to my fig on the last page (ie, LEDs or relay powered by separate +12V - not what the dome-bulb sees (since it is being dimmed), then no dimming or chattering should occur.
But if the only +12V accessable is the dome light bulb's power, then you need some sort of hysteresis to stop relay chatter - eg, an RC circuit, Schmidt trigger or other buffer circuit; maybe a timer.
Page of 3
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
