wiring pin locations
kennyb01
Posted: August 07, 2009 at 5:59 PM / IP Logged
    i am putting a 1998 454 vortec motor out of a 2500 suburban 4x4 in a 1996 chevy 1500 truck 2x2 with a 5.7 motor.  i have looked all over for the fire wall pin locations for both vehicles.  if anyone could point me in the right dirrection i would appreate it.  as a new-be to the sit i am trying to find my way around.  thanks for any informaqtion anyone can give me.
lspker
Silver - Posts: 503
Posted: August 07, 2009 at 9:50 PM / IP Logged
What wiring pins are you looking for?  Believe both ecu are under the air filter.  The rest of wires go through the main harness into the cab to left of steereing colum.
kennyb01
Posted: August 08, 2009 at 4:08 AM / IP Logged
the ones at the fir wall where you nuplug the harness. the computers is diffrent and even though the wire colors ar the sme they are located in diffrent potions on the plug block.  the 454 plug has 3 exra plugs whitch i belive is for the 4x4 control but the harness in my truck has 2 wires that the 454 harness does not have.  i need to find out what these are so that i can change them around.  thanks
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
