dei 529t window functions
chasoy
Posted: August 17, 2009 at 12:47 PM / IP Logged
can the 529T roll bothe my windows up and down at the same time or just roll up at the same time during arming.... i had it installed and the installer told me that i cannot control my windows up and down using 529T
Posted: August 17, 2009 at 1:30 PM / IP Logged
Using TWO 529ts will give you roll up and roll down and close BUT it's simpler to use 1 x 530t for the same functions plus you will get 1 touch from all your  switches if wired directly to each motor, much simpler. N.B. aplies to two windows, double amounts used for four.
OmarR
Copper - Posts: 162
Posted: August 18, 2009 at 3:25 PM / IP Logged
Like Howie said, it is easier to use a 530t for windows.
A 529t can do 2 different motors, ONE direction at the same time. So like 2 front windows close upon arming.
Or it can do 1 motor, like a sunroof or a back window of a Toyota 4runner, OPEN or CLOSE.
IMO, a 529t is typically only good if someone wants just a full close of a single sunroof, single back window, or 2 front windows, AND NO OTHER FUNCTIONS.
If you want the OPEN/CLOSE/VENT functions on multiple windows, then the 530t is your answer.
