Posted: August 18, 2009 at 12:32 PM / IP Logged
Posted: August 18, 2009 at 10:33 PM / IP Logged
Posted: August 19, 2009 at 1:12 AM / IP Logged
Posted: August 19, 2009 at 8:13 AM / IP Logged
Posted: August 19, 2009 at 11:22 AM / IP Logged
Posted: August 19, 2009 at 1:32 PM / IP Logged
Posted: August 19, 2009 at 1:44 PM / IP Logged
Posted: August 19, 2009 at 2:42 PM / IP Logged
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I'm basically taking the above idea, and building a custom truck box for my 2 12" Power Acoustik STW-12's. So the box will sit up like that one does, not like the picture below does, but if you flip the box below, you can see how it would sit.
Again... Flip the above image to look basically like the Kicker Comp's.Height 1: 8"Depth: 17"Width: 32"Height 2: 5"Box Volume: 1.36791, so this gives the subs some room to breath, they'll be in a common chamber. If I divided the chamber in 2 it'd only be like .56 volume, which is well below what these subs require.Now... For the Venting...Width: 6.5"Height: 2.5"I'm not sure exactly what to tune it to? I did 35 hz? I'm trying to get some big bang out of these subs. Is 35 hz good? If so the required vent length will be about 22.8", so I was gonna do a vent on each side of the bottom of the box, so do 11.4" vents.My ultimate question now is, Can I just cut out that rectangular cut out, like on the Kicker box... And just take like 3 strips of wood (keeping them so they make a long chamber with that rectangle just straight through the bottom of the box.)? Or must they intertwine throughout the box like I've seen in photos?I'd also like to know about the tuning part. Is 35 hz good for big bass? I'm not sure what that determines, but 35 hz seems to be common.PLEASE HELP!!!! THANKS!!!!
