'09 lincoln mkz wiring info
N251ea
Member - Posts: 6
Posted: August 21, 2009 at 1:15 PM / IP Logged
I see the wiring information for the MKZ '07 and some of the MKZ '08 information but I'm in need of the wiring information for the '09 Lincoln MKZ.
Thanks!
chev104275
Gold - Posts: 1,436
Posted: August 21, 2009 at 1:41 PM / IP Logged
Remote Start
WIRE COLOR POLARITY LOCATION
Battery BROWN / RED (+) IGNITION SWITCH
Ignition 1 WHITE/ ORANGE (+) IGNITION SWITCH
Accessory 1 PURPLE / GREEN (+) IGNITION SWITCH
Starter 1 BLUE/WHITE (+) IGNITION SWITCH
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH
Speed Sense BROWN / WHITE (AC) AT PCM PIN 65
Parking Lights GRAY / YELLOW (+) DRIVERS KICKPANEL OR SJB CONNECTOR E PIN 30
Low Crr. Pk Lights GRAY (-) AT HEADLIGHT SWITCH OR SJB CONNECTOR D PIN 5
Brake Lights PURPLE / WHITE (+) BRAKE PEDAL SWITCH OR SJB CONNECTOR A PIN 19
Reverse Lights GREEN / WHITE (+) DRIVERS KICKPANEL OR SJB CONNECTOR E PIN 21
Horn BLUE/WHITE (-) AT SMART JUNCTION BOX IN DRIVER KICKPANEL
   PLUG B - PIN #6
Anti Theft RX YELLOW/ORANGE
Anti Theft TX PURPLE / GRAY
Rear Defrost VIOLET/WHITE
   PLUG E PIN 1
Modules
WIRE LOCATION
Module 1 PCM-IS LOCATED UNDERHOOD BEHIND BATTERY
Module 2 SJB- SMART JUNCTION BOX- IN DRIVER SIDE KICKPANEL
Doorlocks/Windows
Door Lock Circuit 3 WIRE NEG
Power Unlock PURPLE / GRAY (-) DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 10
PowerLock GRAY / YELLOW (-) DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 4
Driver Mtr Unlock BLUE/GREEN (REV) DRIVERS KICKPANEL OR SJB CONNECTOR E PIN 27
Driver Mtr Lock GRAY/BROWN (REV) DRIVERS KICKPANEL OR SJB CONNECTOR E PIN 17
Pas Mtr Unlock PURPLE / GRAY
LF Window Up BLUE/GRAY (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn YELLOW/VIOLET (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up BROWN / YELLOW (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn GREEN/ ORANGE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up BLUE/ORANGE (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn YELLOW (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up GRAY/VIOLET (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn BROWN / GREEN (REV) AT MASTER WINDOW SWITCH IN DRIVERS DOOR
Sunroof Open VIOLET/BROWN (REV) AT SUNROOF CONTROL SWITCH
Sunroof Close YELLOW/ORANGE (REV) AT SUNROOF CONTROL SWITCH
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
