2006 dodge ram 3500 diesel vss
jsieg
Member - Posts: 26
Posted: August 24, 2009 at 2:30 PM / IP Logged
Does anyone know the wire color and pin location of the vss wire in a 2006 dodge ram 3500 diesel?
thanks
chev104275
Gold - Posts: 1,436
Posted: August 24, 2009 at 2:55 PM / IP Logged
Speed Sense GREEN/ YELLOW (AC) PCM. IN A BLACK PLUG
DEISEL MODELS PIN 11 AT THE PCM
jsieg
Member - Posts: 26
Posted: August 24, 2009 at 3:03 PM / IP Logged
Thanks Joe, I knew someone on here would have it.
jsieg
Member - Posts: 26
Posted: August 24, 2009 at 9:23 PM / IP Logged
Okay, that's not right. I don't have anything in pin 11 in plug 2. Plug one has a purple wire in pin 11. I know that 2006's are different from 2005 and 2007.
Platinum - Posts: 13,725
Posted: August 24, 2009 at 9:48 PM / IP Logged
The note may be a little confusing,  I too have the same info as posted earlier.
PIN 13. FOR SRT-10 MODELS, LOCATED IN A WHITE PLUG, PIN 27 OR OR DK.BLUE/ORANGE. DEISEL MODELS PIN 11 AT THE PCM.
Is there a DK.Blue/Orange wire?
jsieg
Member - Posts: 26
Posted: August 24, 2009 at 10:02 PM / IP Logged
It might have been DK blue, looked like purple. I will check to see if it has an orange stripe.
jsieg
Member - Posts: 26
Posted: August 25, 2009 at 1:27 AM / IP Logged
okay. Nothing in pin 11 on plug 2. On Plug 1 I have PURPLE / white in pin 11.
On Pin 27 of plug 1 I have a solid dark blue wire
Posted: August 25, 2009 at 5:01 AM / IP Logged
Using a volt meter, and a friend, ground the black lead of the meter, touch and hold the red lead to the wire, have your friend drive the vehicle while you watch the meter.  First try the meter on AC Volts, then if it is not reading a higher voltage as the speed increases, try it on DC Volts.  Check both wires on both meter settings.
jsieg
Member - Posts: 26
Posted: August 25, 2009 at 3:48 PM / IP Logged
Don't have leads long enough and I don't want to start poking wires if I can keep from it.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
