on replacement speakers
nicklemay26
Member - Posts: 14
Posted: August 30, 2009 at 1:47 PM / IP Logged
i have a kenwood kdc-x693 hu and a mtx thunder 704x amp the amps is rated 70w rms x4 the 5.25 components im installing are 90w rms should this amp be enough for these i got them from a friend for $40 with the crossoverrs and tweeters their an older set of mb quarts dsf 213 i also have polk db 6x9 right now and polk db 3.5 but the 3.5 in the right side blew any recommendations welcome these are going in a 96 dodge ram extended cab
nicklemay26
Member - Posts: 14
Posted: September 08, 2009 at 10:31 PM / IP Logged
ok got the mb quarts and a couple questions should i run these and the 6x9s or do away with the 6x9 2nd question on the crossover that came with it there are are four different places fro the speakers on each one one says +3 one says +0 the other says -3 adn one is seperate from the other three i think its fro the small tweeter but where should the main speaker be connected
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
