will a double din fit?
Thack79
Silver - Posts: 526
Posted: September 23, 2009 at 2:31 PM / IP Logged
Will a double din fit in the vehicle without customization???  im concerned about depthness
1998 - 2002 lincoln towncar
haemphyst
Platinum - Posts: 5,059
Posted: September 23, 2009 at 5:00 PM / IP Logged
The height, which is what "double-DIN" is referring to, will have nothing to do with the depth.
Double-DIN is the same depth as is a single-DIN chassis.
If you can't fit your double-DIN head into the dash, it won't be because it's the height it is.
Platinum - Posts: 13,726
Posted: September 23, 2009 at 6:56 PM / IP Logged
haemphyst wrote:
If you can't fit your double-DIN head into the dash, it won't be because of the depth, it's the height that will be the problem.
lspker
Silver - Posts: 503
Posted: September 23, 2009 at 10:11 PM / IP Logged
We have done one, but you will have to trim the clock dezel to fit.  It's not a true double din opening.
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
