ultra start in grand cherokee
puzzleboy
Member - Posts: 17
Posted: September 29, 2009 at 12:47 PM / IP Logged
Hi all.  My first post here.
I'm going to install an Ultra Start remote starter in my '99 Grand Cherokee.  The vehicle does not have a Sentry Key system, so I don't need a bypass.  Wondering if anyone can help me out.
Exactly what wires in the column to tap into, resistor(s) and/or relays required, etc. I only want the unit to function as a remote starter (no door locks, trunk, etc.).  I'm a bit confused with the parking light part too - does it really need a relay and resistor, or just a resistor?  On this site, I've got the wiring description for my vehicle (I'm good with that), as well as the Installation Note for Jeeps which eliminates the reqmt. for a resistored parking light circuit - connects directly to the parking light relay terminal.
Anybody have any idea why my starter (Ultra Start) would have 2 12 volt inputs?  Do I just use one of them?  Also, according to Bulldog Security's wiring guide on their site, it says parking light system should use the negative output from my module.  Can anyone confirm this?
The wires for my starter are:
Starter Output (+) YELLOW
Heater/Accessory Output (+) GREEN
12 Volt Input (+) 30amp RED
Selectable Output (+) WHITE
Ignition Output (+) BLUE
Diesel wait to start input (+ or -) BLUE
Brake Switch Input (+) PINK
Horn Output (-) WHITE/ BLUE
System Ground Input (-) BLACK
Park Light Output (+) 10 amp WHITE
Hood pin switch Input (-) GREEN / WHITE
Tach Detection Input (A/C) BLUE/WHITE
Re-arm Output (-) YELLOW
Trunk Release Output (-) RED / WHITE
Dis-arm Output (-) 250ma BROWN
Negative Park Light Output (-)250ma ORANGE
Ground While Running Output WHITE/ VIOLET
Appreciate any help you can offer!
Jason
puzzleboy
Member - Posts: 17
Posted: September 29, 2009 at 12:48 PM / IP Logged
Disregard, I posted in wrong section, sorry.
tommy...
Gold - Posts: 1,901
Posted: October 01, 2009 at 11:03 AM / IP Logged
It has 2 12 volt inputs...One is for system power...The other is for starter output...This is common...
M.E.C.P & First-Class
