2007 dodge 3500 remote start wire guide?
kobyt
Member - Posts: 7
Posted: October 01, 2009 at 11:07 AM / IP Logged
hey as the title says i need a wire guide for a 07 dodge 3500 please :)
tommy...
Gold - Posts: 1,901
Posted: October 01, 2009 at 11:16 AM / IP Logged
BatteryTAN/RED(+)ELECTRIC BRAKE HARNESS, BLUE CONNECTOR ABOVE JUNCTION BLOCK...LOW CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLY TO THE BATTERY2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Ignition 1PINK/WHT(+)IGNITION HARNESS
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Ignition 2PINK/GREEN(+)IGNITION SWITCH HARNESS...THERE MAY BE NO IGNITION TWO2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Accessory 1VIOLET/BROWN(-)IGNITION HARNESS...USE 610 OHM RESISTOR FOR ACCESSORY, SAME WIRE AS STARTER22007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Starter 1YELLOW/GRAY(+)GRAY PLUG NEAR BATTERY, NOT FOR REMOTE START2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Starter 2VIOLET/BROWN(-)IGNITION HARNESS...USE 180 OHM RESISTOR FOR STARTER2, SAME WIRE AS ACCESSORY2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Anti-Theft TypeDAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Key SenseVIOLET BROWN(-)SAME AS ACCESSORY WIRE...8.5K OHM RESISTOR TO GROUND2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.TachometerINJECTOR(AC)ANY FUEL INJECTOR...
ON DIESEL MODELS THE TACH WIRE IS AT THE ECM ON THE LOWER DRIVER SIDE OF THE ENGINE, FRONT 60 PIN PLUG, PIN 24 OR AT THE CAMSHAFT POSITION SENSOR, LEFT OF THE ECM AT THE 3 PIN PLUG. ON SRT-10 MODELS THE TACH WIRE IS ON THE BLACK PLUG - PIN 18. 2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Speed SenseGREEN/ BROWN(AC)PCM. IN A BLACK OR GREEN PLUG, PIN 32...PIN 13. FOR SRT-10 MODELS, LOCATED IN A WHITE PLUG, PIN 27 OR OR DK.BLUE/ORANGE. DEISEL MODELS PIN 11 AT THE PCM.2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Parking LightsWHITE/ GRAY(+)AT GRAY CONNECTOR, LEFT OF STEERING COLUMN...PARKING LIGHTS ARE NEGATIVE TRIGGER THRU A 1130 OR 250 OHM RESISTOR. MUST USE A RELAY2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Low Crr. Pk LightsWHITE/ GREEN(-)AT LIGHT SWITCH...1.1K OHM RESISTOR TO GROUND2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Brake LightsWHITE/ TAN(+)AT SWITCH ABOVE BRAKE PEDAL
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.Reverse LightsWHITE/ LT. GREEN(+)IN HARNESS, TOP OF DRIVER FENDER
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.HornGREEN/ VIOLET(-)STEERING COLUMN HARNESS..OR CLUSTER,GRAY PLUG,PIN 14.2007 dodge 3500 remote start wire guide? - Last Post -- posted image.
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.DatabusWHITE/ ORANGE(DATA)IN HARNESS AT STEERING COLUMN
2007 dodge 3500 remote start wire guide? - Last Post -- posted image.CANbusWHITE/ ORANGEDATABLACK CONECTOR LOCATED AROUND IGNITION CYLINDER, PIN 6 OF 8 PIN. CONN
M.E.C.P & First-Class
