amplifier wiring, 93 ford mustang lx
red2dr
Posted: October 04, 2009 at 3:27 PM / IP Logged
Can any one tell me the wiring code from the radio plug to the amplifier on a 1993 Ford Mustang LX, the plug is missing? I have the speaker color codes. thanks in advance for the help.
Platinum - Posts: 13,725
Posted: October 04, 2009 at 4:04 PM / IP Logged
Can you tell me what color wires you have?
red2dr
Posted: October 05, 2009 at 10:24 AM / IP Logged
thank you.  I am sure they are speaker wires from the radio to the amp.       Coming  from the amp  Grd. no insulation no color./ yellow  / blue  /   Blue with blk stripe / Purple with white stripe/  Brown / White with orange stripe/ Green / White with red stripe.  I tried grounding the amp the the chassis and picking two speaker wires from the radio and connecting  one to an amp wire  then the other speaker wire one at a time to the remaining seven wires with no result. thanks again.
red2dr
Posted: October 13, 2009 at 10:15 AM / IP Logged
Problem solved, still don't have the speaker wiring color codes but I can figure it out. the replacement radio I was putting in was not powering the amp, fixed that.  Now that the amp has power I can fine the speaker wiring by trial and error, there is only eight of them. Thanks for trying.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
