cruise control for 1994 toyota pickup
mixpix
Posted: October 07, 2009 at 3:42 AM / IP Logged
Hi,
I am new to the forum. I am researching the best possible option for a cruise control  for a 1994 pickup Toyota with 5 speed manual transmission. I would prefer a clean option; willing to spend a little extra money.
Thanks ahead of time for your replies,
mixpix
mixpix
Posted: August 06, 2010 at 3:50 PM / IP Logged
I've since put in a ROSTRA; it works very well. I do think the control switch is a little funky but it works. The other issue I foresee with the switch is it doesn't seem very durable. Perhaps if this switch fails, there is a better one that may be a bit smoother or of heavier quality.
Thanks again that you may direct me to other product accessories that will work with my ROSTRA cruise control that I use for a 1994 Toyota P/U.
To jonhomes: I don't think you posted to the correct topic; unless this is a BOT & is just randomly posting? I've since put in a ROSTRA; it works very well. I do think the control switch is a little funky but it works. The other issue I foresee with the switch is it doesn't seem very durable. Perhaps if this switch fails, there is a better one that may be a bit smoother or of heavier quality. Thanks again that you may direct me to other product accessories that will work with my ROSTRA cruise control that I use for a 1994 Toyota P/U. To jonhomes: I don't think you posted to the correct topic; unless this is a BOT & is just randomly posting?
