need wire gauge size
Platinum - Posts: 13,726
Posted: October 10, 2009 at 6:42 PM / IP Logged
i am an idiot wrote:
Have you tried placing the key in the switch and turn it to the run position, and try to remote start it.  Will it start now?
Did you turn the key to the run position?
sublime44
Member - Posts: 25
Posted: October 10, 2009 at 7:52 PM / IP Logged
yes i did.
Posted: October 10, 2009 at 8:08 PM / IP Logged
I am not real sure if the passloc system looks for a signal between off and on, or between on and start.  It may look for it between on and start, if that is how it works, just turning it on will not tell us anything.  Maybe some of our hands on guys can let us know how it works.
KPierson
Platinum - Posts: 3,527
Posted: October 11, 2009 at 7:40 AM / IP Logged
The passloc system I worked on yesterday sent the resistance after cranking the motor.  (this was in a 2001 Grand Am).
What happens if the vehicle is running and you remote start it and remove the key?
Kevin Pierson
boxhead78
Copper - Posts: 84
Posted: October 12, 2009 at 10:04 PM / IP Logged
it won't work it only work if the key is in the off position
boxead78
