08 jeep liberty
lysakjm
Member - Posts: 8
Posted: October 19, 2009 at 10:30 AM / IP Logged
Looking for a diagram to install an Ultra start remote starter.... Thanks
tommy...
Gold - Posts: 1,901
Posted: October 20, 2009 at 3:36 AM / IP Logged
BatteryBLUE/RED(+)IGNITION SWITCH HARNESS...THIS WIRE ONLY SUPPLYS 10 AMPS OF CURRENT, FOR HIGH CURRENT APPLICATION GO DIRECTLY TO THE BATTERY08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Ignition 1PINK/WHITE(+)IGNITION SWITCH HARNESS
08 jeep liberty - Last Post -- posted image.Accessory 1VIOLET/BROWN(-)IGNITION SWITCH HARNESS...THIS WIRE IS ALSO THE KEYSENSE AND SECOND STARTER WIRE, USE A 580 OHM RESISTOR FOR SECOND ACCESSORY, FOR REMOTE START INFORMATION08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Starter 1YELLOW/GRAY(+)UNDER HOOD AT MODULE ON DRIVERS FENDER...*NOT FOR REMOTE START* *08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Starter 2VIOLET/BROWN(-)IGNITION SWITCH HARNESS...
THIS WIRE IS ALSO THE KEY SENSE AND ACCESSORY WIRE, USE A 180 OHM RESISTOR FOR SECOND START FOR REMOTE START INFORMATION08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Anti-Theft TypeSENTRY KEY® VEHICLE IMMOBILIZER
08 jeep liberty - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
08 jeep liberty - Last Post -- posted image.Key SenseVIOLET/BROWN(-)IGNITION SWITCH HARNESS...THIS IS THE SAME WIRE AS THE SECOND STARTER AND THE ACCESSORY WIRE, USE A 8500 OHM RESISTOR FOR KEY SENSE, FOR REMOTE START INFORMATION08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Speed SenseDARK GREEN/ BROWN(AC)AT PCM MODULE ON PASSENGER FENDER UNDER HOOD
08 jeep liberty - Last Post -- posted image.Parking LightsWHITE/ VIOLET(+)IN HARNESS IN DRIVER KICKPANEL
08 jeep liberty - Last Post -- posted image.Brake LightsWHITE/ TAN(+)AT SWITCH ABOVE BRAKE PEDAL...ALSO WHITE/ DARK GREEN IN HARNESS IN DRIVER KICKPANEL08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.Reverse LightsWHITE/ LIGHT GREEN(+)IN HARNESS IN DRIVER KICKPANEL...ALSO AT MODULE UNDER HOOD ON DRIVER FENDER08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.HornDARK GREEN/ VIOLET(-)IN HARNESS AT STEERING COLUMN
M.E.C.P & First-Class
lysakjm
Member - Posts: 8
Posted: October 20, 2009 at 9:26 AM / IP Logged
Thanks.... would you have the wiring info for the locks also. I plan to just use a normal transponder key and control everything off the Ultra remote. I don't want to carry the big factroy key with the remote on it when the remote start will do everything. Thanks again!
tommy...
Gold - Posts: 1,901
Posted: October 21, 2009 at 10:28 PM / IP Logged
Power UnlockVIOLET/DARK GREEN(-)IN HARNESS IN DRIVER KICKPANEL TO DOOR...UNLOCK IS (-) THROUGH A 100 OHM RESISTOR, SAME WIRE FOR LOCK, MUST USE RELAYS08 jeep liberty - Last Post -- posted image.
08 jeep liberty - Last Post -- posted image.PowerLockVIOLET/DARK GREEN(-)IN HARNESS IN DRIVER KICKPANEL TO DOOR...LOCK IS (-) THROUGH A 330 OHM RESISTOR, SAME WIRE FOR UNLOCK, MUST USE
